Ground
Old 10-14-07, 06:38 PM
Ground
Stupid question. What do you do with a ground when you have a plastic box and a simple light fixture (plastic) that has no ground only hot and nuetral?
Old 10-14-07, 06:50 PM
HotxxxxxxxOKC's Avatar
No question is stupid.
Just cap it off with a wire nut.
Old 10-14-07, 07:55 PM
You don't even really need the wire nut. Just coil the grounding wire up and tuck it into the back of the box.
Old 10-14-07, 09:09 PM
Whatever you do, do not cut the wire short. If you ever install a light that needs a ground, or extend the circuit you will need to use the ground wire.
Old 10-15-07, 07:39 AM
Good idea. I figured you don't really do anything with it just beinsure.
