3 terminal switch question
Old 10-17-07, 07:48 PM
i have a 3 terminal switch like this i need to put in my car to connect a fog lamp
how do i know which one is ground? or does it really matter? Im new to this stuff
Thanx..
Old 10-17-07, 11:07 PM
ray2047's Avatar
Normally three connectors would indicate two functions. Does the fog lamp have a high and low beam? Except in some circuits such as horn the positive is switched so the ground would not be connected to the switch, only the positive. Did the switch come with the fog lamp? How many wires from the fog lamp?
Old 10-18-07, 05:21 AM
First thing is none of them are ground.
The way you use that switch depends entirely on the switch. There are many combination that this switch could be.
It could be center off, up on item one, down on item two.
It could be up one on, down two on.
There s hould be a drawing on the side of the switch indicating a common terminal and the NC(normally closed) and an NO(normally open), or other combination of how the switch works.
Old 10-18-07, 06:21 AM
The only reason a switch like this needs a ground is if the switch is lighted.
If you cannot find a wiring digram on the switch then use a meter and ohm out the switch.
Old 10-18-07, 10:01 AM
Never thought of the light. Good point about the ground for a lighted switch.
Old 10-18-07, 02:03 PM
well yea, sorry bout that, it is a lighted switch like this
let me give the scenario, the car is prewired, i found the 3 wires needed to connect to the switch. One for power (blue), one for ground (black), and one for the fog light itself (green)...just wanted to know which terminal is for what. It has no diagram on it
Old 10-18-07, 02:59 PM
If it has no drawing then you need to reference the manufacturer literature. You need to be sure the light part is 12 volts. It could be 120 volts.
