run cable in breaker panel bottom?
Old 10-19-07, 07:13 PM
I was wondering if there's anything in particular I need to know when connecting my meter box and main breaker panel back to back. The entrance of the SEU cable will come in the bottom of the panel, but then, I need to run up side to the top of the Panel to connect. I was told I can not run it thru the 2x4 wall stud and has to be in same block as panel. I guess just use braces on the inside to adhere the SEU against the side? In doing this, what about the Bare Neutral just keep if away from touch the inside panel metal or does it matter ? (3 wire of course)
Thanks
Jim
Old 10-19-07, 07:56 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Upvote on 1 Post
Bare neutral? there should be an overall covering that covers the neut as well.
Actually, that ends up being bonded to the panel tub anyway so it would not really matter if it were bare.
can you explain that statement a bit. I am having a difficult time understanding what you are asking.
Old 10-19-07, 08:04 PM
HotxxxxxxxOKC's Avatar
I think he was saying he cannot feed the cable through a 2x4and that the feed wire must enter the same cavity (between the studs)as the panel.
Old 10-19-07, 08:07 PM
running SEU on inside side of Main Panel
Should have mentioned... I'm backfeeding into main...
Sure, the inspector said I couldn't run the SEU cable thru the 2x4 stud when coming in below the main panel as I wanted to feed the main panel from the top (so I didn't have the run the SEU up thru the inside of main panel). Supposedly, the SEU must stay in the same square (area) as the main panel is located. Or, basically you can't run it thru another Stud and run it up to thru the top of same Stud to enter the main panel from the top. I live in Ohio so who knows...but he's the guy doing the inspecting...
Ok, so it's cool to run SEU on the inside of main up the side, should I use plastic clamps as metal would bond the bare neutral to the back metal...or you said this doesn't matter as it's connected anyway then?
Old 10-19-07, 08:17 PM
Only clamp you need is the one bracing the cable as it enters the panel. Just run the cable along the side of the panel and bend it down into your main breaker.
Old 10-19-07, 08:26 PM
nap's Avatar
nap
nap is offline
New Member
that is what is referred to as "the authority having jurisdiction" or AHJ. They get to interpret the rules although they are not empowered to make new rules. Sometimes it is simply easier to acquiesce to the AHJ's call rather than trying to appeal it.
Old 10-19-07, 08:31 PM
splicing and running SEU to right/left sides inside main
Should I split the wires running 1 hot to the left and 1 hot w/neutral going up right side so I can do my loops bf connecting? does it make diff? ...I was thinknig of leaving grey jacket on SEU until even with top connectors and then splicing. This way it protected until at top...but, I know usually all jackets are usually striped upon immediate entrance into mains... but, would be safer and could always strip off later if they don't like that. With the 1st way running up left/right sides might be best, not sure.
Old 10-19-07, 08:40 PM
nap's Avatar
nap
nap is offline
New Member
I tend to run one side or the other. It looks neater. As to stripping the outer sheath; I would simply strip is right after entering the panel box. It makes the wire easier to work with.
Old 10-19-07, 09:31 PM
Stripping the sheathing just inside the panel is required by code.
Old 10-19-07, 09:42 PM
nap's Avatar
nap
nap is offline
New Member
I suspected that but was not sure. As I posted before, I don't do resi so SE cable is not a common material for me. I had thought of the direction for NM when the question came up.
Old 10-20-07, 12:18 AM
I'm just a bit surprised with running the SEU 3-wire with a bare neutral up about 2ft inside box seems a little well not so safe, but, if code says sheathing off suppose I'm ok. Seems to me like they'd want a cover of some sort for runnning inside from a bottom or backfeed.... I'll post results, but, keep thread going for any more Q&A!
Old 10-20-07, 09:20 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Unless your main breaker operates in an up/down direction must panels can be installed with the main at the bottom. This way you would not have all the extra wire in the panel.
