Wiring stove to new breaker box.
Old 10-31-07, 01:40 AM
I added a new breaker box because the old one was incredibly dated and at capacity, and there was no main breaker. I was tripping breakers if I tried to run my microwave at the same time I was doing dishes with my portable dishwasher. I also started remodeling the living room and it was a perfect oppurtunity to update the wiring in the walls while the drywall was off.
Anyway, I added a new breaker box which is about 2' from the old one. I pulled out all the old breakers from the old box and I am currently utlizing it as a temporary junction box. All the old wiring that used to go to the old breakers are wire nutted to new wires which go to my new breaker box.
The problem is the stove is 220 and the wiring for it is huge, I would say about 4 gauge. The holes in my 50a 220v breaker is too small to take that gauge, but I need to lengthen that by about 2' anyway to reach the new breaker box.
So, I need to extend the wiring for the stove from my old breaker box to my new breaker box about 2'. What is the best way of doing this? I used wire nuts for the rest of the house, it was relatively small 12 or 14 gauge. I would need to go buy HUGE wire nuts to splice the 3 wires which are 4 or 6 gauge. I think I need 6 or 8 gauge wire for it to be to code. Does anyone know for sure?
I don't have access to replace the entire run to the stove though, so splicing is my only option. I want it to be to code though.
Old 10-31-07, 03:52 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Is the #4 wire aluminum or copper?
Old 10-31-07, 03:58 AM
I think the neutral is aluminum and the two hots are copper, but I could be wrong, I am going off memory as I am at work right now. They may all be aluminum.
Old 10-31-07, 05:26 AM
Received 67 Votes on 62 Posts
If there is no ground(four wire cable) you are not permitted to extend it. It must be brought up to current code of a four wire feeder.
Old 10-31-07, 07:07 AM
Well, I need a stove, so how would I extend it?
Old 10-31-07, 07:08 AM
Replace the entire cable.
Old 10-31-07, 10:37 PM
Thanks, I just twisted it together and used black tape to cover it.
Old 10-31-07, 11:02 PM
core's Avatar
LOL this one made my evening!
Old 11-01-07, 12:21 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
At least you should use split-bolt connectors, rubber tape, then plastic electric tape (or friction tape).
Old 11-01-07, 12:34 AM
Thats actually what I did. I was trying to make a point when I said I twisted them together and used black tape. This is the second time I can remember me asking a question on these forums and the moderators refused to give me an answer because what i was doing would not be too code, or some other reason.
I imagine the moderators job is to make sure that people do everything to code, and do it safely so the website is not liable incase someone burns their house down or is hurt, but by refusing to give an answer like that just increases the chance that someone IS going to do something stupid.
I am doing this to bring my house up to code, but it's not going to happen overnight because I simply DO NOT have the money.
Old 11-01-07, 06:39 AM
ray2047's Avatar
It is a difficult line to walk sometimes made even more difficult because of the forum owners stringent rules regarding any debate on issues.
Old 11-01-07, 02:50 PM
LOL, that's great! You should probably edit the post, though, so anyone who happens on it from a search in a similar situation doesn't think you're serious
Old 11-01-07, 04:32 PM
chandler's Avatar
I was just going to ask how in the heck a human "twisted" #4 copper or aluminum. If you must have the stove tonight, then you are dedicated to doing it without the help of the forum. No one here can give you information that will place you in harm's way. The codes are in place for a reason. Split connectors, friction tape, electrical tape and a prayer will get you hot tea. But fix it right as soon as you can do it.
Old 11-02-07, 12:47 AM
if you are talking about the old " SE " cables with two large conductors with small netual conducter wrapped around the large conductors if so,, YOU can not extend it at all.
the code is very strict on this.
how far the stove connection to the new breaker box ??
#8-3 NM [ 40 amp ] or #6-3 NM [ 50 amp ]
will do the job fine and IMO it not any harder than try to run with #12 NM's only they are larger but can be run very simiar as the 12NM's can be.
something like this >> http://images.builderssquare.com/Ori...49371_Orig.jpg
if so let us know
Merci, Marc
Old 07-31-08, 01:24 PM
chipcarver
could you run the existing wire to a suitable branch box (one that could handle 50amp) then run a new wire the rest of the way?
would this meet code?
thank you
Old 07-31-08, 06:11 PM
Received 21 Votes on 17 Posts
No, the cable MUST consist of THREE insulated conductors (one of which must be white or grey) AND an equipment grounding conductor that may be bare or with green insulation.
Old 07-31-08, 07:06 PM
wgc
wgc is offline
subpanel instead of junction box
You could always use your old panel as a subpanel instead of a junction box: then you are not extending the old oven circuit or modified it in any way. However it sounds like you're way past the point you could easily do that.
