Running Power to shed+lights+socket
Old 11-01-07, 05:30 AM
Exclamation Running Power to shed+lights+socket
I want to run power from an existing socket to power 1 double plug and a 2gang 2way light switch controlling 2 internal and 2 external lights.
I searched through my box of electrical stuff and came up this this idea..
I plan to run the wire out through the external wall into conduit and run it (buried about 500mm) alongside the footpath down to the shed.
In the shed will be a MCB-RCD combo switch
I have 10mm (two core + earth) for the main supply and 6mm (two core + earth) for the light/socket circuits.
The lights are all 60w bulkheads lights.
Is this possible with the things I have or will I need to get some more?
Old 11-01-07, 08:28 AM
Where are you located?
Old 11-01-07, 11:12 AM
Received 132 Votes on 118 Posts
Your talking UK wiring. This site is mostly dealing with North America wiring . There are one or two former European electricains who come around. If you wait long enough they might find this post.
