48" wall plugs
Old 11-01-07, 02:51 PM
48" wall plugs
According to several electrical do-it-yourself books,I originally installed the wall plugs in my detached garage at 12" off the floor. The building inspector said I need to raise them to 18" due to vapors sometimes found in garages. I am considering mounting them at 48" so they will be at a convenient level for work benches I might install in the future. Are 48" plugs in a garage legal?
Old 11-01-07, 03:33 PM
HotxxxxxxxOKC's Avatar
Yes..........good luck with your project.
Old 11-01-07, 09:53 PM
The 18" rule only applies in commercial applications unless you have a local code requirement.
Old 11-02-07, 06:29 AM
Received 54 Votes on 51 Posts
Mine are at 48" and I like that height.
Old 11-02-07, 06:34 AM
I prefer the 48 inch, or maybe even 50 inch height. At that height the receptacles won't get hidden behind a piece of plywood leaning against the wall.
As an aside, there is no minimum height for receptacles on a residential garage wall. (barring a local requirement). The inspector may be confused.
Old 11-02-07, 08:39 AM
Thanks everyone, the 18" requirement is a local code. I'll change the bottom of the box to 48" this weekend.
