Electrical Outlet Reset Button
I have an outlet where the reset button keeps popping out a few minutes after our refrigerator is plugged into it. I checked the circuit breaker but it isn't tripped. The outlet will be fine for a few minutes, but then the reset button trips within minutes of the refrigerator being plugged in. If anyone has any advice on how I can fix this, I would greatly appreciate it.
What joed said. But when did this start happening? Is this a new house, or did you just recently move the refrigerator or something?
You could try plugging in a motor such as a vacuum cleaner into that receptacle. If it trips the GFCI is definitely at fault. If this receptacle is behind your refrigerator where it cannot be accessed then you don't need a GFCI there anyway. Otherwise you could try replacing the GFCI; newer ones are not as prone to nuisance trips.
But if you have changed nothing and it just recently started doing this, your refrigerator might be going bad and the GFCI is doing exactly what it's supposed to do.
but some case i heard i dont know if that true but i know it did happend to me once the defrost heating element went bad on me and tripped the GFCI on me so that one of few thing with self defrosting fridges can get tricky.
Merci, Marc
Merci, Marc
