Electrical outlets no power
Old 11-05-07, 09:11 PM
to whom it may concern,
I have 3 electrical outlets in the garage suddenly lost the power at same time. I removed the cover plates and checked the voltage between black wire and green screw, and it showed 120 Volts. Measured voltage between netural and green screw show 3 volts. But if I plug in appliance to the outlet, nothing works. What could possibly cause this ?
Your help is greatly appreciated.
Old 11-05-07, 09:16 PM
Old 11-06-07, 05:16 AM
You have an open neutral. You proved that to yourself. Search EVERY receptacle (or other location) on the circuit, working or not. Somewhere the neutral has opened.
As you are searching remake ALL wire nutted connections with new wire nuts and move all back stabbed connections to the screw terminals.
Old 11-06-07, 06:40 AM
Received 87 Votes on 80 Posts
Could be a simple as a tripped GFCI and you are measuring phantom voltages. Look around in the garage or outside your house for a tripped GFCI recepatlce.
