ground and neutral again (sorry)
Old 11-12-07, 05:27 AM
N
I realize this is very similar to a question that was just covered, but from the other poster's pictures it looks a little different and I want to be sure what I'm doing is ok.
My main breaker panel has 2 neutral/grounding bars ( the ones that individual circuits neutral an ground wires are connected to).
The one on the left has the ground cable which leads to a ground rod outside the building. The one on the right has the neutral from the electric service. There is a large strap connecting the two bars. There is a bonding screw on the right side which (I believe) is used to ground the body of the panel.
This is a very new Siemens panel.
My question is: when I am connecting a receptacle or light circuit, can the ground wire and neutral wire be put onto the same bar or do the ground wires go to one side and the neutrals go to the other side?
Old 11-12-07, 05:36 AM
Received 442 Votes on 367 Posts
In your case they can go into the same bar. The can not go into the same hole. Only one neutral per hole is permitted.
Old 11-13-07, 07:32 PM
C
Technically you can put both wires on the same bar, but it is good workmanship to use one bar for grounding, the other for neutral.
Old 11-13-07, 07:39 PM
D
Received 1 Vote on 1 Post
It does not matter where you put them as they are mechanically and electrically connected.
They are considered one bar.
Old 11-13-07, 07:45 PM
Unclediezel's Avatar
One step better.......(Or at least another alternative)
Buy two ground buss kits....mount them to the panel (There are pre drilled holes for these) and use these for ground terminations. Leave the bonding screw in place, and run a #6 ( or appropriate for your svc amperage) "Jumper" between the neutral buss and your new ground busses....
My panel had double and triple wires under the screws ---so Im a big fan of "More is better" when it comes to this situation.
"Anyone who feels this is "Overkill" --Hasnt seen My Panel"-
Old 11-14-07, 01:21 PM
How about a picture
Old 11-14-07, 03:12 PM
Originally Posted by johny2050 View Post
How about a picture
" Sorry, but the flash just glares off all of those WHITE wires
