wiring for electric baseboard heater
Old 11-19-07, 02:54 PM
E
I have just installed a 4ft 1000watt 240v baseboard heater, in a upstairs bedroom.
It is running on a dedicated 20amp double pole circuit with 12/2 cable running from the circuit breaker to a junction box in the wall. And then split out to the heater. (Eventually I plan to run another heater off it, but right now that is the only thing connected to the 20amp circuit.)
I only had enough 12/2 wire to reach the juction box, so I used 14/2 to run to the heater.
My question is wether that is safe or not? I am worried about the 14/2 getting too hot running off the 20amp 240v circuit. Does it sound safe or should I replace the 14/2 with 12/2? thanks
Old 11-19-07, 03:00 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
You need to replace the 14-2 with 12-2, or you could change the breaker to a 2 pole 15 amp.
Old 11-19-07, 03:40 PM
E
will a 15 amp provide enough juice?
Old 11-19-07, 05:24 PM
B
Be safe - keep the 12-2
1) Techically a code violation - You should not mix 14 and 12 gauge on a 20 amp circuit - so ditch the 14/2.
2) I would not change the breaker to 15 amp especially if you are going to add more heaters. Changing the breaker is more difficult than adding the correct wire ( you can use the 12/2 wire left when you add the extra heater)
3) Your 1000w heater will draw 4.2 amps - you should learn how to calculate the loads if you are going to continue with heater installs
Old 11-19-07, 05:27 PM
HotxxxxxxxOKC's Avatar
At full power with the heaters, I'm calculating a 16.66 amp load rating. A pro can double check my calculations.
total wattage / volts 4000/240 = 16.66
Old 11-19-07, 05:40 PM
pcboss's Avatar
The 1000 watts is the total wattage of the 4 foot unit, not 1000 per foot. A standard heater runs 250 watts per foot.
Old 11-19-07, 05:41 PM
Received 441 Votes on 367 Posts
He only has one heater of 1000 watts. It is 4 feet long, not 4 1000 watt heaters
Old 11-19-07, 05:52 PM
R
It is NOT a code violation to mix 14 and 12 gage wire on a circuit, provided that the breaker is only 15 amps.
That being said, it is NOT a good idea to have 12 gage wire at the panel, 15 gage wire downstream even if the breaker is 15 amps. Someone someday will think the breaker can be up-sized to 20 amps, when it cannot.
Replace the 14-2 with 12-2. Make sure that the junction box is permanently accessible. You must be able to remove the cover and get at it at any time, without having to remove drywall.
Old 11-19-07, 05:53 PM
I
Received 45 Votes on 43 Posts
A 240V 15A circuit may supply up to 2880 watts of baseboard heaters.
A 240V 20A circuit may supply up to 3840W of baseboard heaters.
You need to either replace the 20A breaker with a 15A or replace the 14/2 with 12/2. I recommend that you replace the 14/2. This will avoid the later confusion of someone seeing #12 wire in the panel and incorrectly thinking that it would be okay to upsize to a 20A breaker.
Old 11-19-07, 07:03 PM
Yikes, I must really need sleep...
