Wire height
Old 11-20-07, 07:50 PM
mick7's Avatar
Wire height
On new home construction is the any specific height to run wire horizontally through the stud bays in walls?
Old 11-20-07, 08:03 PM
R
No. Whatever works. You may want to avoid the obvious picture height.
Z
Received 319 Votes on 285 Posts
No.
It's usually run 8-12" above the receptacle height, or 8-12" above the switch height. You want to stay away from common nail locations, baseboards, chair-rail height, picture frame height, and at the top of the wall in case crown molding is installed. Granted, the carpenters should be using short enough nails that it isn't a problem... but one never knows.
It does help though if all your holes line up, it's easier to pull the wire and ends up looking cleaner (if you're having it inspected).
Good luck!
Old 11-21-07, 08:50 AM
I
Received 45 Votes on 43 Posts
Depends on how tall your helper is with the angle drill resting on his knee... I guess about 20-22" off the floor is typical.
