Reload this Page >
The standard for installing a receptical...ground pin up or down?
Old 11-21-07, 08:05 AM
L
Out of curiosity, what is correct, the ground pin up or down, or is there a standard? All of mine are up, but it seems as though every time I get an appliance with an offset plug wire, it plugs in upside down. Logically I would think that the pin goes down which would be facing ground, but what do I know?
Old 11-21-07, 08:16 AM
I
Received 45 Votes on 43 Posts
There is no standard in the electrical code for receptacle orientation. Some electricians install grounds up, some install grounds down; some commercial jobs specify one way or the other from the engineer. Sometimes, the electrician will install a receptacle upside down relative to the others in the room to indicate that receptacle is controlled by a switch. In the US and Canada, grounds down has historically been far more common.
It can devolve into an almost religious debate.
Old 11-21-07, 08:19 AM
Received 442 Votes on 367 Posts
Nothing in the code. Ground down is most common for the reason you stated, offset plugs hang properly.
Old 11-21-07, 08:52 AM
Received 1 Vote on 1 Post
Over the past few years, there have been thousands of posts made in this forum on this one question. Lots of opinions, but no consensus.
Old 11-21-07, 10:27 AM
G
Check out this site you may see a lot more then up or down in the furture.
http://www.360electrical.com/
Old 11-21-07, 10:40 AM
T
Received 68 Votes on 64 Posts
Great idea
Now, if we followed Tesla's lead, all we would have to do is get the plug "near" the recept...no need for any holes.
Old 11-21-07, 05:24 PM
Rollie73's Avatar
All commercial applications in my area are ground up.
The reasoning (of the engineers ) is if something were to fall and hit a plug... or the metal plate were to come loose... it would strike the ground pin and the plate wouldn't become energized.
Personally, in all the residential installs I've done its ground down.
Old 11-21-07, 07:24 PM
nap's Avatar
nap
nap is offline
New Member
that is hilarious.
