gfci
Old 11-21-07, 01:20 PM
3
gfci
Hi everybody,
My house is old, all electric wires are 2 wire. There are no ground wire. I just build new bathroom in the back house, so inspector tested outlet said I need GFCI
I need to replace GFCI outlet or GFCI breaker?
Do I need to run the ground wire?
Thanks
Old 11-21-07, 01:44 PM
I
Received 45 Votes on 43 Posts
A new bathroom requires a circuit that is up to code. This requires installation of a new 20A circuit for the bathroom receptacle(s), which much be GFCI protected.
You cannot use an existing, ungrounded circuit for a new bathroom.
The new circuit must have a ground wire (which will be included in 12/2g cable).
Old 11-21-07, 02:30 PM
3
gfci
I used the 20A existing wire now.
I used the 20 A existing wire now. I installed a new outlet
then with normal receptacle. Now I need to replace with GFCI receptacle.
So I need to run new ground wire from this outlet to ground or Can I just connect the ground wire from GFCI receptacle to metal outlet box??
Please advice
Thanks
Old 11-21-07, 03:49 PM
Received 442 Votes on 367 Posts
You do not need a ground wire to install a gfci. Depending on how servere the remodel you may be required to pull a whole new circuit with a ground. It sounds as if your inspector is not requiring the complete new circuit.
Old 11-21-07, 11:55 PM
3
gfci
Thanks Joed,
The inspector did not required whole circuit.
He said as long as GFCI tester is ok (on/off test) then Ok
Do I install receptacle or breaker??
Can I just conect ground wire from receptacle to metal box??
