Brown Light and Fan Switches
Old 11-25-07, 08:05 AM
B
I'm adding some light and fan switches next to some existing ones on the wall. The existing ones are dark brown, which is the best match to the stained knotty pine walls in our mountain cabin. Of course, I'd like to match the current brown switches, rather than changing them all out to black, or spray painting white ones.
Decora style for all of the above would be best, that would make it easier to have the same wall plates if I need to switch things around later.
Any sources for the brown light and fan switches? I'm not finding much as the big box stores, and looking online has been hit or miss.
Old 11-25-07, 09:41 AM
5
http://www.leviton.com/OA_HTML/ibeCC...&section=10087
You can get these at an electrical supply house. Since brown is not a common "fashion" color these days, the home stores don't have much,.
Old 11-25-07, 09:43 AM
Received 326 Votes on 281 Posts
Take the cover plate off one of the existing ones. The manufacturer name should be stamped on the metal mounting strap. Go direct to the manufacturer site.
