debounce
Old 11-26-07, 08:34 PM
evan_ellerbe's Avatar
Exclamation debounce
how could you set up a debounce circuit with 12vbattery a switch and a solenoid?
if you hold the switch down in a debounce circuit will it send a continuous flow or just a pulse?
Old 11-27-07, 12:02 AM
core's Avatar
A traditional debounce circuit will send a continuous flow. That's the point -- continuous instead of several pulses as the switch is thrown. You can easily modify the circuit as needed though.
Honestly, you're going to need to actually _understand_ these R-C circuits at least on a basic level if you're going to design this stuff. A little trial and error too. The schematic posted in the other thread is about as simple as it gets if you ignore the relay. If you're looking for "connect this wire to this wire" type step-by-step instructions I don't know that you're going to get that here given the custom nature of this.
