Double throw for generator
Old 12-22-07, 02:14 PM
I see some 80 amp square-D double throw switches on E-Bay. I have a 20kw pto generator and 150V Main breaker box. Will an 80 amp double throw be okay? Thankyou, Ted
Old 12-22-07, 04:21 PM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
I'm guessing you mean a 150 amp Main Breaker?
Old 12-22-07, 08:53 PM
Are you sure about that 80 amp rating?
I have never heard of any electrical equipment other than fuses and breakers with an 80 amp rating.
Standards are 30, 60, 100, 200, 400, 600, etc.
If you intend to connect this switch after your main, the switch size needs to match the service size or feeder it is serving even though it is a manual switch.
Old 12-22-07, 09:13 PM
Are you thinking about the below item???
http://cgi.ebay.com/Square-D-Safety-...QQcmdZViewItem
Old 12-22-07, 10:06 PM
let me make a correction in case someone else think this one and by the way this is a 60 amp double pole transfer switch there is no 80 amp transfer switch on market at all
Merci, Marc
Old 12-23-07, 03:16 PM
If the switch is designed for a transfer switch, you would set up a subpanel for the circuits you want to have emergency power, with that transfer switch between it and your main panel, with a 60A breaker serving it, and an inlet run from the generator.
