Replacing switch with a switch/receptacle combo
Old 12-31-07, 11:46 AM
A
I am having trouble replacing a normal flip switch (for a light fixture) with a receptacle/switch combination.
My switch just controls the light fixture. I have the following set up in the junction box:
1. Black, white and ground wires which I believe comes from the light fixture.
I connected the wires as listed on the switch/receptacle combo switch. Now my problem, after wiring it up I do not have power to the receptacle but the light works perfectly
Could you please help me.
Old 12-31-07, 11:50 AM
R
Nobody can help you with this setup. You don't have a neutral wire. A neutral wire is required for a receptacle. You have a switch loop where both wires are hot wire.
The only way you can install this device is to replace the existing cable with a cable containing three insulated conductors and a ground wire. This would 14-3 or 12-3.
This does not even address whether it is allowed by code to put a receptacle on this circuit where the switch presently is located.
Old 12-31-07, 12:02 PM
If you can replace the cable as Bob mentioned, it's 99% certain that you would still be code compliant with this. If there's an accessible attic above the room, replacing the cable is likely not that hard.
Old 01-01-08, 02:13 PM
They make GFCI switch/outlet combinations if this is an area that requires it.
Old 01-01-08, 02:23 PM
Received 247 Votes on 217 Posts
It doesn't matter if it is GFCI or not. It can't be installed in this situation.
Old 01-01-08, 08:50 PM
This is an excellent time to follow the advice in Strategery's signature line, rather than the advice in his post. No cigar.
Old 01-01-08, 09:16 PM
B
I think what Strategery was saying was "If you were to pull the neutral wire needed to wire this combo, you could always use a gfci switch/outlet combo to make it a gfci compliant circuit"
