Best Insulated Screwdrivers?
Old 01-03-08, 05:24 PM
I am in the process of starting a wiring project on a house I bought. I was wondering if there is best set of insulated screwdrivers to get or if they are all pretty much equal. I wanted to get a set that would last and be reliable. Thanks.
Old 01-03-08, 05:53 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You shouldn't be working on a project live so you shouldn't need an insulated screwdriver. What are you planing to use it for?
Old 01-03-08, 05:57 PM
I want to be safe. I will only work on a circuit when there is no power but I am a safety nut so that is why I planned to use them.
Old 01-03-08, 08:53 PM
Unclediezel's Avatar
A screwdriver is only as safe as where you put it. There is no need to spend stupid $ on something that claims to be "insulated".
Having said that, Being in the auto biz, I like Snap-on, although they are a bit pricey for "Around the house " tools.
Home depot and Lowes, both carry the KLEIN tool line, which is pro grade, but not quite a s pricey. Stay away from cheapo, dime store screwdrivers, They dont last.
Old 01-05-08, 06:22 PM
most electrical tools packaging will also tell you what they are rated at for taking volts
Old 01-05-08, 08:09 PM
mango man's Avatar
put your money into a voltage detector like this instead to be sure the power is off
http://tmt.stores.yahoo.net/volalnowintw.html
Old 01-05-08, 08:23 PM
Received 15 Votes on 15 Posts
Voltage detector is a nice item. Understand though, that a circuit that has no voltage on it COULD become live when it becomes disconnected. That is, a connected neutral won't trip the voltage detector, yet when you disconnect a neutral with a load, the wire now could be lethal.
Old 01-05-08, 08:49 PM
Get some screwdrivers that have the word Klein on them.
