Running wire through a finished ceiling
Old 01-05-08, 10:20 AM
I'd like to run 220v to my garage to be used mostly for a welder. I can run it in the space between the basement ceiling and next level floor. About 12 feet of the run is an area where the ceiling is finished so I wouldn't be able to attach the wire to the floor joist. I'm assuming I can't just let the wire lay on the sheetrock. What is the best way to deal with this?
Thanks,
Brent
Old 01-05-08, 10:29 AM
pcboss's Avatar
Received 30 Votes on 26 Posts
Wires that are fished between access points are permitted to be unsecured to the framing members.
Old 01-05-08, 02:46 PM
Your assumption is incorrect. In a finished wall or ceiling the wires do not need to be secured.
Old 01-05-08, 07:00 PM
Be aware that 240-volt circuits are not general purpose as are most 120-volt circuits. 240-volt circuits are individually designed for the specifications of one specific piece of equipment. Even among welders, one might need a different circuit design than another.
