Converting 3 way switch
Thanks in advance. I have just finished a HT install in my basement such that half the room is for movies and half for ping pong etc. The basement has 2 lights controlled by 2 3-way switches on opposite ends of the room. Since movies need dark and games need light, I would like to be able to control the lights individually. Power is from one switch. What is the easiest way to accomplish this.
Sorry. I dont need any additional switches. I just want the existing switch at each location to control only the light nearest it. Hope that is clear.
Do you want one switch at each location, each switch to control a light? Yes.
power -> switch 1 -> light 1 -> light 2 -> switch2
At the first switch:
Remove the first switch and replace with a normal on-off switch. You can also leave the first switch in place and just use the common and one traveler terminal.
Connect the incoming power black wire to the black wire going to the lights and pigtail this to the switch.
Connect the red wire to the lights to the other switch terminal. Connect the two white wires together with a wire nut (they probably are already).
At the first light:
Connect the red wire from the first switch to the black wire of the light.
Connect the black wire from the first switch to the black wire going to the second light.
Connect the white wire from the first switch to the white wire of the light and to the white wire leading to the second switch.
Do not use the other two insulates wire to the second light, cap them off with wire nuts.
At the second light:
Connect the white wire from the first light to the light.
Connect the black wire from the first light to the black wire going to the second switch.
Connect the red wire from the second switch to the black wire of the light.
Cap off and do not use the other two insulated wires from the first light and the white wire to the second switch.
At the second switch:
Cap off the white wire.
Connect the red and black wires to the terminals of a new normal on-off switch. OD you can use the common and a traveler terminal of the three way switch.
At all locations connect the ground wires to each other, to the box if metal, to the light, to the switch, etc.
At the first light:
I bet you could have figured this out if you had drawn a picture.
In fact, I encourage you to draw a picture of the existing setup and see if you can modify that to this point.
Actually I was planning on doing this and thought I could figure it out but then today I stumbled across this forum looking for solar panel info and thought I could some great info here and save myself some time and worry. Which I did! Although I have done quite a bit of home electrical, it still makes me nervous. Especially working at my Moms > 100 yo farm house with old BX wiring. Thanks again.
