Calculating leakage resistance of a capacitor?
Old 01-12-08, 05:53 AM
Can anyone help me answer this question? I need to know how to work out the following for an assignment....
100pF capacitor. Mica dielectric relative permittivity Er=12 and resistivity p=10(power14) ohmM. How to calculate leakage resistance?
Cheers for any help!
Old 01-12-08, 06:17 AM
chandler's Avatar
Received 3 Votes on 3 Posts
Check this out in PDF format. May have the forumulae you need. Googled leakage resistance of capacitor.http://www.keithley.com/data?asset=6076.
Old 01-12-08, 06:32 AM
Thanks Chandler, read through it but it's not in there :-(
Old 01-12-08, 07:50 AM
I think you are looking for a figure in MegOhms per Microfarad. Check this link: http://www.avxcorp.com/docs/techinfo/eqtant.pdf
If that doesn't help, check the text and reference books for the class you are taking, and let google be your friend!
Old 01-12-08, 08:08 AM
Thanks Tough, I think the answer may be in there 'somewhere!'. I've spent hours upon hours with Google and today decided to join a forum to try and find the way to solve this...
My course books just don't explain how to get there at all
I'll read through that link some more and see if it takes me there
Old 01-12-08, 09:52 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
What about your teacher. Isn't this what (s)he is for, to help you?
Old 01-12-08, 10:23 AM
Received 14 Votes on 14 Posts
you show already a resistivity number
although your units don't make sense. What is ohmM? Do you mean Megaohms (Mohm)? In any case, if your given the parallel resistivity in ohms, that already is your "leakage" resistance. Trick question...
Old 01-12-08, 11:24 AM
Yes I thought that too, the leakage is already specified....
Ohms/metre is the OhmM by the way.
There is definately something I'm missing here! Thanks for the help so far though
And ray2047, what can I say..................
Old 01-12-08, 12:18 PM
OK, new plan
The problem wants IR in ohms. You are given C, Er, and the specific IR of mica R(ohms/Meter).
1) You first need to calculate both the area of the the plate in Meter*2, AND, the thickness of the insulator in Meters. for this, use C, Er and a constant. You gave us C and Er; the constant you need to know or look up.
2) So, with area A(meters*2) and thickness T(meters), use the given mica IR to get the actual capacitor resistance. That's your answer.
As always, watch your units.
you won't get actual thickness and area. You will get a ratio to get the given capacitance. Since voltage rating is not part of the problem, you could use thin dielectric and smaller area, or thicker and more area. Its only the ratio you need to solve the given problem.
Old 01-12-08, 12:41 PM
Thanks Telecom guy! I'll try and apply that tomorrow. it's getting late here and I've spent all day working out electrical equations, so my brains fried for now
Thanks for all the help!!!
Old 01-13-08, 02:36 AM
Thanks again for your help. I'm not positive I'm right yet but I get to a conclusion at the end of the equations my leakage resistance is 1 Gig Ohm....
Old 01-13-08, 04:54 AM
At what frequency?
Old 01-13-08, 05:25 AM
I didn't include a frequency
The question is multi part and the following part I calculated time to dissipate at open circuit as 100 seconds.
Old 01-13-08, 06:44 AM
not frequency dependant
Originally Posted by Rick Johnston View Post
At what frequency?
Although some capacitor parameters will be freq. dependant, leakage is typically thought of as a DC parameter.
Mica is a very good insulator, and 100pF is a small cap. 1Gohm could be correct, but I haven't run the numbers.
Old 01-13-08, 08:14 AM
Thanks Telecom Guy, a bit of reassurance I'm on the right path
Old 01-17-08, 02:07 PM
Question leakage resistance
Puppy dog, I think I'm stuck on the same question as you.
So now looking for your help. Did you get to the answer? If so can you give me some pointers. I've seen the other help about using the constants for area and thickness but dont get it?:
Old 01-18-08, 09:01 AM
Hi Joe, if wer'e doing the same course we may be able to help each other... I do have the solution now to this question Send me an email to [email protected]
Cheers!
