Pls Help! Wiring Two lights, EOL switch.
Received 0 Votes
Hi All. New to this forum. I'm trying to add some lighting into our 100yr old farm house and need help wiring two new lights fed from a nearby outlet with a wall switch at the end of the line. Wiring is in place but I can't get the switch to control both lights. Sheesh, some handy man!
Received 0 Votes
Tell us what you have and what you did. We can then tell you what you did wrong.
Hint: You need 14-3 or 12-3 between the two lights. You can't do what you want using only 14-2 or 12-2
