Spa GFCI load center loud humming
Old 01-17-08, 06:23 AM
I have a SBSG GFCI Load Center LC220-D-50 for my hot tub. Just before Christmas it started to hum rather loudly. For what it's worth tripping the GFCI outlet and pulling the plug stops the humming but resetting starts it again. Any ideas as to why it started to do this and how to make it stop short of pulling the plug? Thank you.
Old 01-17-08, 06:25 AM
The breaker is likely loose in the panel. It needs to be checked. It may just be loose or it may need to be replaced.
Old 01-17-08, 06:32 AM
Okay, I'm somewhat new to electrical repairs, what is the best way to check this AFTER I shut off the power to the box?
Old 01-17-08, 06:55 AM
You want to shut off the breaker in the main panel.
Open the panel and see if the breaker is loose. It should be obvious how to remove the cover of the panel.
