Maximum Amps
Old 01-21-08, 05:12 PM
Maximum Amps
I have to apologize for this question but I simply could not find an answer on any website. It's probably a ridiculous question but I know nothing about electrical wiring.
I have a 15 amp circuit breaker dedicated for my sump pump which draws 8 amps. What will happen if I plug in a dehumidifier that draws 8 amps as well to the other outlet next to the sump pump plug? Therefore, I would have 16 amps on a 15 amp circuit breaker.
Will this not work? What will happen or not happen? Thank you!
Old 01-21-08, 05:31 PM
Um it will trip.
I'm glad I could clear things up for you there ...
Old 01-21-08, 05:51 PM
Will it trip immediately once both are plugged in?
Old 01-21-08, 06:15 PM
HotxxxxxxxOKC's Avatar
If the start up AMPs for these devices are 8amps, but when they are up and running, it's lower.
I think the circuit would trip if you turned on both units at the same time, but possibly not if you started one, then start the other one a couple seconds later.
I personally would not have these on the same circuit.
Old 01-21-08, 06:17 PM
Received 136 Votes on 122 Posts
If both of them run at the same time it could trip. If they only run one at a time you will have no problem. I don't know how you could control that only runs though.
Do you want to take a chance that your basement floods?
Old 01-21-08, 06:33 PM
Thanks for the great advice! How can I check if my circuit breaker is 15 amps or 20 amps?
Old 01-21-08, 06:40 PM
Uh look in your panel box and find the one that controls thereceptacle(s) in question and read weather it says 15 or 20 on the handle...
Old 01-21-08, 07:19 PM
I feel so stupid. Thank you!
Old 01-21-08, 07:46 PM
There have been worse questions asked
