Voltage question - at the risk of sounding very stupid.
Old 01-22-08, 11:45 AM
I have a fan that came off a computer cabinet which is rated to move a very high volume of air. This fan, shape wise, is PERFECT to install in my attic as a vent fan. The only problem is that the fan is for 240 volts, and my house of course only has 120 volts.
Someone told me that it would be safe to plug the fan into 120 volts, as it would just spin slower. Moving less air would be desirable given the high capacity of the fan in quesiton.
I want to make sure this is SAFE (as in no fire hazard), before I even try it.
Anybody ?.
Thanks.
Old 01-22-08, 11:51 AM
Ed Imeduc's Avatar
Wink
You might check on the motor some you can set to run on 220V or 110V. But if not DONT TRY AND RUN IT ON 110V.
Old 01-22-08, 11:54 AM
There is no selector switch for voltage.
Old 01-22-08, 12:20 PM
Your house has 240 volt. You may not knopw how to wire for it, but it has 240 volts.
Old 01-22-08, 05:07 PM
I understand, but let me ask the original question again......
A fan is rated for 240.....you plug into 120.....it spins slower....is there any safety risk by doing this ?.......
I know if you go the other way and plug 120 into 240 you'll burn whatever it is......
Old 01-22-08, 08:05 PM
1Geniere's Avatar
What do you consider risk?
An undervoltaged motor will have less torque, it may not start, draw maximum current, and eventually trip the breaker... or the windings may melt their insulation, short out and trip the breaker.
Or nothing noticible will happen but the motor will NOT run at rated rpm and therefore draw more current and run warmer; normal wear and tear will accelerate.
If its a listed device, it would not have been tested for 240vac operation.
Old 01-23-08, 06:56 AM
Thanks for the detailed answer. Exactly what I needed.
