A 3-way mystery!
Received 0 Votes
A 3-way mystery!
There's a light in my kitchen that's on a 3-way switch. One switch is on the west side of my kitchen, the other is on the east side.
For aesthetic purposes, we decided to replace the west switch with a new 3-way switch. So I tripped the circuit breaker, removed the old switch, and connected the new switch using the same wiring arrangement. I reset the circuit breaker, tested the new switch...and had problems.
I thought I had carefully identified which wire was where in the original switch. Apparently not, and now I'm lost.
The east switch is untouched; looking at the switch from the back the white wire is connected to the upper-left terminal, the red wire is connected to the upper-right terminal, and the black wire is connected to the lower-right terminal (marked "common" on the switch).
If I connect the west switch in the same configuration it works like this:
The only thing I can imagine is maybe I damaged a wire when I replaced the west switch? If so, which wire would I be looking to fix?
Help!
- With the EAST switch in the UP position, the WEST switch does nothing (doesn't turn on the light).
- With the EAST switch in the DOWN position, the WEST switch will turn the light on in the UP position and off in the DOWN position.
- With the WEST switch in the UP position, the EAST switch will turn the light on in the DOWN position and off in the UP position.
- With the WEST switch in the DOWN position, the EAST switch does nothing (doesn't turn on the light).
- With the EAST switch in the DOWN position, the WEST switch will turn the light on in the DOWN position and off in the UP position.
- With the WEST switch in the UP position, the EAST switch does nothing (doesn't turn on the light).
- With the WEST switch in the DOWN position, the EAST switch will turn the light on in the DOWN position and off in the UP position.
Help!
Received 0 Votes
All three way switches are NOT the same. Just because one 3 way switch has it's common in one place does not mean that another 3 way switch will have it's common in the same place.
Identify the common by either looking at the terminal colors (the common is an odd color) or by reading the indicators on the switch.
Put the common in the right place on each switch and the travelers in the right place and your setup will work.
If all else fails, and you forget what was on the common, there are only three wires that can go on the common on each switch. That means by trial and error you can get the light working properly in 9 attempts total, 3 if you only messed with one switch.
Received 0 Votes
The common wire on the east switch, as well as the common wires on the other two 3-way switches in my house, are all colored black. The side terminal for the common wire on all of the switches all have a black screw in them (the others are brass). Without pulling out the multimeter and testing it, I would therefore believe that the black wire and black screw on the west switch are the common wire/terminal.
And yes, I only messed with one switch.
Received 0 Votes
I am still having trouble with this. :-(
I found an excellent page describing this circuit and how to troubleshoot it:
http://www.naturalhandyman.com/iip/i...l/inf3way.html
Using these instructions I identified the common, which is indeed the black wire. The common terminals on my switches are black screws, while the traveller terminals are brass screws.
So, again, the common is in the correct place but the switch still doesn't work properly, and swapping the traveller terminals doesn't help.
WTF??
WTF??
Received 0 Votes
Received 0 Votes
Then obviously the common is NOT in the right place. Three ways are not magical. Get the commons right and the light works. it's very simple, as suggested I recommend you just try swapping wires to the common screw until you get it.
If your positive you have the common correct, [which you don't] check the bulb just so your not chasing a phantom problem.
Received 0 Votes
Start Over?
Since the original switch worked fine and you are only replacing for a newer or prettier one, re-install old switch the way it was and see if all starts working again. if it does that lets you know you don't have any breaks in the wire or possible other problems and will allow you to start over and carefully trace you steps. Just an idea
Received 0 Votes
Theoretically that means that I have only two possible options: the red and white wires on the two remaining terminals. They either go on white at the top and red at the bottom, or vice-versa. But neither works properly. And since I never messed with the other switch that eliminates the wiring on that side.
Received 0 Votes
But as you seem to have all the answers, I'll ask you: Since the black wire is the only wire that comes up with a 120V current on the multimeter, which wire do you think is the common wire? And since the black terminal on the switch is the only terminal that has "COMMON" written next to it, and it's the only black terminal on the switch (the other two are brass), which terminal do you think is the common terminal? You're so insistent that I have misidentified the common wire and/or terminal, so the answer here (according to you) cannot be "the black wire and the black terminal" so..... What's the answer?
Received 0 Votes
No you are wrong.
The reason you most likely have power on that wire is because it is actually a traveler from the other switch. If you were to flip the other switch then check I''m sure you'd find power on a DIFFERENT wire. The correct wire to use as the common in this case would be the wire that never registered current.
I will not argue that the common terminal is the black screw. I know this for a fact , but I will argue that it's not the black wire. This is very apparent since the light doesn't work , so unless your bulb is shot I'd feel very confident saying you wired it wrong.
Swapping the travelers will make no difference to the operation of the switches.
I also think you have the common wire wrong.
Please tell us how you determined which wire is the common.
Received 0 Votes
Pretty sure he "found" the common by checking checking for voltage. Probably just found a live traveler... I'd wager to bet that power comes into the other box and his common is actually the black from the light...
Received 0 Votes
I think I'm just going to give it up and call an electrician.
Received 0 Votes
This is not rocket science.
There are only 9 combinations to try. Try them all and you will eventually get it right.
Pay an electrician and you will feel foolish when he or she figures it out very quickly.
Using a meter to find the common won't necessarily work. If you test the To make that test you must have the wires completely disconnected from both switches. Have any wires connected and you risk finding a traveler from the first switch that just happens to have power on it.
