Jaccuzi Problems
Old 01-23-08, 12:34 PM
Jaccuzi Problems
Have a recently installed jacuzzi tub... when the pump kicks on it runs for 5 seconds or so and then the thermal protection kicks it off. The motor gets hot to the touch. Leads me to believe its a power issue. It looks to be installed with 14gauge wire and is on a 60 amp breaker... is it possible that its got too much power at the gfci?
Old 01-23-08, 12:43 PM
14 gauge wire w/ a 60 amp breaker?
No freaking way!
Old 01-23-08, 12:44 PM
14 gage wire on a 60 amp breaker is a fire hazard. Either you are looking at something wrong or you have a real problem.
I suggest that you start at the beginning.
Old 01-23-08, 12:53 PM
Received 42 Votes on 40 Posts
If it's true that you have #14 and a 60A breaker, then the wire is much too small and whoever installed this unit was incompetent. Take a closer look at exactly what you have and report back. Look for wire colors, gauge, conduits, breakers, etc. Start at the panel and tell us everything between there and the tub motor.
Old 01-23-08, 01:27 PM
Some pictures would also be helpful.
Try and get one with the firemen if possible.
