Wiring a Stove - Quick Question
Old 01-24-08, 04:32 PM
Hello all,
I'm trying to hard wire in a new range. The wires out of wall are bare / white / black. Voltmeter across Black and White indicate 240.
Stove book only shows 4 wire hook up (black/bare/white / red).
Do I Split the black from wall and wire to red / black terminals on stove?
Thanks
Old 01-24-08, 05:02 PM
C
The instructions should show wiring for a 3-wire installation. If not, you might want to check with the manufacturer to ensure that it's OK for a 3-wire circuit.
You have an older 3-wire stove circuit, where the neutral wire is also used to "ground" the stove. These circuits are no longer allowed as they are less safe than 4-wire stove circuits that have a separate ground. (In the same way, 3-wire dryer circuits were once allowed, but are not now.) You are allowed to continue using the circuit, but if you remodel, or otherwise need to modify the circuit, code would require it be replaced with a 4-wire circuit.
The black and white wires are your two hots, and the bare is your *neutral*. You have no ground wire. Most likely, the correct wiring method is stove black to wall black, stove red to wall white, stove white AND bare to wall bare.
That said, confirm with the manufacturer that this is correct. It's hard to imagine the instructions not mentioning what to do for a 3-wire install. Since we're talking grounding, and grounding is for safety, it's imperative that you get this right to have a install that doesn't just "work", but is "right" and "safe".
Old 01-24-08, 06:24 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
Is a bare neutral even grandfathered. If this is newer NM doesn't #6-2 with ground have a smaller bare then the insulated conductors? Maybe this is a 240v only source. The stove could be 120/240v.
Old 01-25-08, 09:31 AM
I
Received 45 Votes on 43 Posts
What is the make/model of the stove so we can look up the manual online?
Sometimes, it's basically up to the inspector's judgment.
Old 01-25-08, 09:50 AM
Unclediezel's Avatar
Wouldnt this REQUIRE a 4 wire ckt...?
Old 01-25-08, 10:00 AM
R
Not necessarily. A 120/240 volt stove can legally be connected to an existing three wire circuit, as long as the three wire circuit was legal at some point. This is just like a dryer.
Old 01-25-08, 10:28 AM
So the four wire is only "SAFETY" compliant? no other 'functional " differences?
I was lead to believe that 4 wires (120/240) were introduced to operate the newer style of electronic controls, and timers/clocks, as well as the "Safety " upgrade to older 3 wire systems.
Old 01-25-08, 10:32 AM
R
New installations are required to be four wire for stoves and dryers where the unit requires 120 and 240 volts.
Older installations were permitted to be three wire and existing older installations are grandfathered.
Clearly a four wire setup is safer and whenever possible three wire setups should be replaced.
Old 01-25-08, 10:37 AM
"This is why I love this place"---thanks Bob..
