electrical question
Old 01-26-08, 04:17 PM
electrical question
Over the weekedned a fuse went out in the box which has the fridge on it, and a two more outlets in the kitc hen. I unplugged everything and then switched the fuse back on and there is still no power to those outlets.
ideas?
Old 01-26-08, 04:26 PM
nap's Avatar
nap
nap is offline
New Member
possibly a bad connection at one of the receptacles. If the are back stab, this is not uncommon.
The bigger question is why did the fuse blow. When you find the bad connection, repair it but be aware, the underlying problem may still be there.
Be sure to remove the fuse for the circuit you are working on except when actually checking for voltage.
Old 01-26-08, 05:26 PM
Also check for the GFCI repectale because you mention kitchen area so please check that out as well if have it there.
Merci, Marc
