Installing digital dimmers at 2 locations help
Old 01-26-08, 05:53 PM
I am wiring 4 sconces together to be controlled by 2 digital dimmers in separate locations.
The digital dimmers came as a Master and Remote. I am installing the dimmers at the end of the electric run with the sconces being at the beginning at the run.
I have 2 wire running to the first sconce from the breaker box. I have 2 wire running from the first sconce to the remaining 3 sconces. I have 2 wire running from the first sconce to the Master dimmer box. I have 3 wire running from the Master dimmer box to the Remote dimmer box.
I have followed the instructions as best I can and hooked up both dimmers. I can only get the Master to control the sconces. There is power going to the Remote dimmer but it does not work.
With a Master/Remote digital dimmer, is it possible for them to be at the end of the run or do they have to be at the beginning of the run? The instructions only show then hooked up at the beginning of the run with the lights being at the end
Old 01-26-08, 06:24 PM
Received 87 Votes on 80 Posts
Need more info on the dimmers you are using and how they are connected up.
Old 01-26-08, 06:41 PM
They are Aspire LED Smart Dimmers by Cooper. One is a master and one is the "accessory" or remote dimmer.
Here is a pic... http://www.westsidewholesale.com/ind...&CATEGORY=3182
I'll see if I can explain how they are hooked up or get some pics. I am a electrical newbie so bear with me
Old 01-26-08, 07:43 PM
Sconce...
Master switch box...
Remote switch box...
Old 01-26-08, 08:44 PM
Need the wring diagram for those dimmers. I can't find it online. I don't think they wire like a normal three way switch.
Found the diagram.
Master is wired wrong. Incoming power(white with tape) goes to master switch black.
Master red goes to black to light AND to remote(use the red).
Master Blue goes to remote. Use the black.
You only need two wires to remote so cap the white at both ends. Connect remote blues to red and black.
Go to page c5 here to see diagram.
http://64.239.63.88/catalog/
Old 01-27-08, 08:09 AM
Found the diagram.
That worked!! Thanks a MILLION!!
