Covering heating window units during winter
Old 01-29-08, 08:55 AM
Cool Covering heating window units during winter
Hi,
Is there a way to cover heating window units during the winter so air does not blow through?
Thanks,
Ginger
Old 01-29-08, 08:56 AM
What is a "heating window unit?"
Old 01-29-08, 09:09 AM
Question Heating window unit
It is a unit that sits in the opening of a window just like an AC window unit. We have four of them in different rooms, and all are combined AC and heating units. Does that explain it any better?
Thanks
Old 01-29-08, 09:16 AM
If you are not using these and they have been turned off or unplugged or other wise disconnected, then you can cover them with an air conditioner cover or similar cover.
Old 01-29-08, 10:12 AM
Being used
They are being used. Does the air that is being "sucked" in come from the inside for the heat, or the outside like the AC/cold air? If it is from the inside and is just being recycled, then it seems as though I could cover it anyway. If not, then are there any kind of vents that could be put on, outside, and be turned for wind deflection?
Old 01-29-08, 05:11 PM
Look for an "outside vent" or "outside air" switch or lever on the units. If you see one, turn it off. If that doesn't stop the cold air from blowing in, check the area surrounding the units. Cold air could be coming in from the window frame.
