Generator
Received 0 Votes
Generator
I have a generator with the following specs:
15kw
18.75 kva
72 amp
230v
50Hz
Single Phase
Could anyone advise me what a suitable automatic voltage regulator and transfer switch would be for use with the generator to connect it the the household supply.
Any help regarding this would be appreciated
Thank-you
John
15kw
18.75 kva
72 amp
230v
50Hz
Single Phase
Thank-you
John
Are you in the US or Canada? If so and there is not a typo in the specs you can't use the generator. The output frequency is wrong. US is 60 Hz. Fifty hertz would most likely be European. Ebay purchase?
Received 0 Votes
The generator should have its own regulator, unless things are done differently where you are.
Apart from that, you should seek help in a board that more caters to your locale.
