Main Disconnect before meter bank
Old 02-08-08, 08:00 AM
Where the service enters the house there is a 200 amp main disconnect that then feeds the meter bank and then the panels are fed from the meters. I need to replace these panels. Am I correct to assume that these panels should be wired as sub panels because of the main disconnect before the meter bank?
Old 02-08-08, 08:14 AM
Unclediezel's Avatar
correct......
Assuming the neutrals are bonded to ground prior to the panels you are replacing.
I would , however , consult local electrical code before completing this.
Old 02-08-08, 08:23 AM
Thanks
Thank you. The bond occurs in the main disconnect. I have never ran across this situation before and wanted to double check.
Old 02-08-08, 08:31 AM
Im curious how you got the disconnect BEFORE the meter???
Old 02-08-08, 08:37 AM
New one to me
I've never seen it before and can't imagine seeing it again.
Old 02-08-08, 10:14 AM
Received 77 Votes on 71 Posts
Sounds like possibly an apartment building with separate billing per unit. I would expect that the main disconnect is locked and sealed so you could not access power before the meters.
Old 02-08-08, 11:02 AM
If the panels are not located at the metering equiptment, then they are panels supplied by Feeder Conductors protected by a breaker at the metering equiptment, and are wired as such.
All Neutral teminations in a panel supplied by Feeder Conductors are required to be isolated from Ground.The Wiring Method for the Feeder Conductors must include an approved Equiptment Grounding Conductor .
Old 02-08-08, 11:14 AM
Exactly my point. I remember hearing something about this being a "West Coast service upgrade".....
