welding machine
Old 02-10-08, 07:32 PM
welding machine
Can a 3 phase 440 volt machine be converted to 220 volt?
Old 02-10-08, 07:36 PM
nap's Avatar
nap
nap is offline
New Member
if it is designed to be, yes. If it isn;t designed to be, then no.
Old 02-10-08, 09:19 PM
Check the nameplate info it will tell the voltage and amparage [ primary side ] if only show one voltage then it not possible to change voltage at all if show more than one voltage then yes it can do but you may have to check with the manufacter or owner manual for more info.
Merci, Marc
