How to use a screw extractor
Received 0 Votes
Hi all, I got a stripped screw try to remove, I bought a screw extractor, like this:
http://www.vermontamerican.com/Produ...191753&I=72481
However, I have no idea how to use it. Can you guys explain to me how to use this tool? I tried to use power drill with it, it basically makes the screw head bigger but do not help to remove the screw.
Thanks
Thanks
It looks like you are supposed to drill a hole in the screw to the appropriate depth listed on that web page, using the correct sized drill bit listed on that same web page, then use the screw extractor (in a drill, set on "reverse") in order to extract the screw.
Received 0 Votes
You are supposed to drill a hole in the screw exactly as small as you are able to hammer in the conical end. The you use a wrensh to get the screw out.
This is a quite rough metode, and is mainly used to remove broken bolts or pipes fitted into a quite solid base.
dsk
dsk
