Low voltage at wall switch
Received 0 Votes
I have a four gang light switch box in my house which I recently purchased. One of the switches does not seem to work anything when it is switched on. I tested the voltage and there is only 40 volts coming to this switch, the other three work fine and have 120 volts. What are some causes for this low voltage?
Between where and where using what type of tester?
Probably "phantom voltage" from a digital meter. If you use an analog meter or simple neon bulb tester, you will likely see no power on the disconnected switch.
and there is only 40 volts coming to this switch...What are some causes for this low voltage?
The 40v is meaningless, especially if you used a digital meter. If there is no neutral in the switch box you can't measure the voltage. If this box has switch loops there may be white wires but no neutral. If a white wire is connected to a switch is not a neutral (or certainly shouldn't be).
The switch may no longer be connected, or for a receptacle or in case it is needed at some future time for a ceiling fan and light.
Previous Thread
Next Thread
