GFCI circuit breaker and 2-wire circuit
Old 03-02-08, 03:44 PM
Older house, most circuits are 2-wire, including 15A circuit to a bathroom we're doing some work in and would like to have the 2-prong outlet protected by GFCI. Without ground wire there, I can't just replace that outlet with a GFCI outlet (or even a 3-prong grounded outlet).
Can I use a GFCI circuit breaker on that 2-wire circuit and be protected as though that outlet was a GFCI outlet (grounded properly)?
Or run a 3-wire from the breaker box to a GFCI outlet, and move the 2-wire circuit from the box to the GFCI outlet?
JU
Old 03-02-08, 03:58 PM
Unclediezel's Avatar
You most certainly can....
There will be specific instructions in the receptacle box pertaining to your situation. There will also be a "Stick-On" label that must be affixed to the gfci recept to denote.."No equipment Ground". Gfci will function as described , even without a Ground conductor.
Old 03-02-08, 05:17 PM
Wonderful!
Thanks much, Unclediezel. Now I can go shopping.
JU
Old 03-03-08, 10:37 AM
core's Avatar
You can do that, but keep in mind your bathroom is not up to code. If this bathroom work you are doing is a complete remodel then you should run a new 20A circuit for the bathroom.
Old 03-04-08, 06:10 AM
H
How do you figure that?
It's NEC article 406.3(D)(3) that specifically allows this installation.
How can that be "not up to code"?
Just curious
steve
Old 03-04-08, 07:44 AM
core's Avatar
I did not say this installation was not allowed by code. I said the bathroom is not up to code. Perhaps I should have said 'up to current code' for clarity. Whether this is required depends on how involved this bathroom work is.
210.11(C)(3) requires a 20A circuit for these receptacles. The original poster has said it is a 15A.
He didn't say whether this 'work' was just wallpapering or a remodel.
Old 03-04-08, 09:16 AM
Sorry guys , I missed that part.
A new sink fixture and some paint is different from a Remodel.
Jullian....Dependant upon how drastic your bathroom work is, a new circuit may need to be run to comply with current electrical codes.
Minor work would not necessarily require any changes, so youve gone above and beyond minimum requirements..
A quick call to your local township office will rectify any confusion.
