Switch removal
Old 03-08-08, 08:58 AM
Switch removal
I have a switch on my main wall of my living room that controls the outlets on the adjacent wall. I am taking down part of the wall that the switch is on and would like to eliminate the switch altogether. I really don't need the switch to control the outlets just as long as are on all the time. My question is how do I get rid of the switch while still keeping the outlets hot all of the time.
Old 03-08-08, 09:05 AM
chandler's Avatar
Received 3 Votes on 3 Posts
Code won't allow the removal of the switch if it is the only switch in the room that will operate an outlet (receptacle or light). If you have a fan/light operated by another switch it will be doable. Do you have additional lighting switching in that room?
Old 03-08-08, 09:45 AM
Unfortunately, no. It is the only switch in the room and controls one of the two outlets on the adjacent wall. So, by code, I need to keep that switch there in order to operate that one outlet? If that is the case, I suppose I will have to relocate the switch rather than eliminate it.
Old 03-08-08, 10:43 AM
Received 115 Votes on 105 Posts
Code requires a switch at the entrance to a room that will turn on a light. That light can be plugged into a receptacle or it can be a fixture mounted on the ceiling or wall.
