Misinformation
Received 0 Votes
Misinformation
I found the following on this website under Electrical Projects - Replacing a Switch: 6. Connect a new switch to the wires. Always curve or twist wires in a clockwise direction around screws so wires will wrap around screw when it is tightened. The black wire should go to the brass colored screw and the white wire to the silvery colored screw.
Would you moderators care to comment or, better yet, do something about this? Or do your switches have silvery screws? No wonder people are confused.
Yes, it's typical here in the U.S. to have brass screws for the hot, and silver for the neutral.
Switches don't really matter for that fact. If you reversed the wires, ON would be when the switch is down..
Position of the wires on a switch does not determine whether UP is on. On would be down if you rotated the switch during installation. The labels would then read NO instead of ON.
Nope, no matter where your wires are on a sp switch, on is on and off is off. Sometimes you do have white wires to the switch, although they should be taped to indicate they are involved in a switch loop. But on a sp switch, there is no designation as to the screw color. Three and 4 way switches, different animal. Black, or andonized screw is always either line or load, and the others are travellers.
Received 0 Votes
I did check it out sure engouh you caught the mistake and i am glad you gave us a head up with it.
as other mention about the single pole switch they are all brass colour however if you are looking about the 3 way it get little tricker if not carefull you will have to find a darker colour screw or word say " common " that is the common connection for 3 way's other two is bright brass.
but however this question do come up from time to time but unforetally it is true if you have alum branch wire in the house you must used the switch or devices marked CU/AL rating and the screw will look like alumish colour so you really have to watch out on that one [ this area is very tricky to termated it right and from my past experince it will be wise to defered to the electrician due the issue with alum wire ]
Merci,Marc
Merci,Marc
