Device box adapter?
Device box adapter?
Hello, I have a double gang box that originally had 2 devices in it. Now, I will only be having one device in the box. Is there and adapter ring or something so the single device can be centered in the 4" box?
-THANKS!
-THANKS!
Presumably you are talking about a mud ring set in sheetrock. I could find nothing a few years back. If you are talking about metal surface mount, you should be able to find a centered arrangement.
What kind of device?
For a standard duplex receptacle, Leviton makes a 2-gang with one blank gang that mounts directly on the box holes, so you don't need a mounting yoke.
For a GFCI or Decora, Leviton makes a similar plate but you need a mounting yoke.
I don't recall if they make a toggle switch plate with similar arrangement.
Your cheapest option is to use a 2-device where one side is a standard toggle, and put a dummy toggle in there. You can get cheap toggles for less than a buck, while a toggle blank filler costs a couple of bucks. (I do not know what code says about switches that do nothing; since I was being inspected I just bought the blanks.)
If you need more info on the Leviton stuff re-post in this thread and I will look it up.
If this is a mud ring yes it very easy to get a single opening verison it will centred up.
many bigbox stores and hardware store useally stock this item and it is pretty common item you can find but however a instering twist here if you have nail on box with standard two gang box you can get a blank yoke [ sometime it will call filler yoke ] to fill in unused opening on the switch box cover.
simuair to this mud ring
if that is the item you are talking about ??
if not plese let me know i know there is other verison you are talking about
Merci,Marc
Merci,Marc
Sorry, I misunderstood. I thought you were looking for a sheet metal piece to mount on the existing mud ring that would convert the 2-gang to 1-gang.
French's picture is the best choice when you already have the wall torn up or the box edges are otherwise accessible.
