ac on cars
Some specifics? I know it helps keep me cool in the summer heat when I'm in my car. If you want it repaired you might try:
http://forum.doityourself.com/forumdisplay.php?f=91
huh?
You will find ac inside the alternator, inside the radio, and all around the navigation system
He is in Electrical A/C
How about some electrical info.
When the A/C switch is pressed, the HVAC control module grounds the A/C request signal circuit. This input will request the engine control module (ECM) to ground the A/C compressor clutch relay control circuit, which will switch the A/C COMP relay. With the relay contacts closed, battery voltage is supplied to the A/C compressor clutch assembly.
Automovite electrical system or Air Condting system in the car ??
If that is the case let us know we can move the thread to proper location
Merci,Marc
Merci,Marc
Looks like a hit and run posting but don't some of the new cars have a 120v (inverter) courtesy receptacles? Maybe that's what he is asking about. We had another post here asking about the ground on those.
