need help wiring dishwasher and disposal
i have all 20 amp breakers in my box do i need a 20 amp receptacle or a 15 amp receptacle. i want to run a 12/2 cable from the 20 amp breaker to a receptacle under the sink to plug in the diposal then into a switch for the disposal then from the receptacle i want to hadwire my dishwasher but i only want the switch to control the disposal can i do this
In the US if you have more than 1 spot to plug into you can you a 15 amp receptacle. A standard receptacle is a duplex and could be used as you have2 places to plug in to.
