Easy receptacle question.
Hello all,
I'm almost ashamed to ask this, but it's late, worked all day and my mind needs a recharge.
I wired my whole house when I built it 8 years ago, and "knew it all,(almost)" back then. now, my memory is a bit rusty.
My son just bought a 45 year old house, and last week I upgraded his service to an all new 200 amp service...no problem.
Today I was ripping out half of the old wiring in his kitchen and replacing it with new. I have a new 15 amp circuit for the lights, and new 20 amp circuits for counter plugs, (3 circuits total for those) A 20 amp circuit for the refrigerator, another 20 amp circuit for the microwave.
My question is simply this. On the countertop circuits, I am using 20 amp GFCI's, then off of those a few more recepticles,,(only 2 or 3 more.) Do those receptacles need to be rated 20 amp? Could they be 15 amp receptacles?
i'm having a hard time finding 20 amp recepticles....I am finding "pro-line" 15 amp receptacles. I don't remember what I used when I built the house. I like using the better recepticles...the pro-line ones, not the el-cheapo ones, but I just do not remember what receptacles I need to use for a 12-2 wire/20 amp circuit....??
thank you in advance for your help.
Frank D.
Frank D.
Thank you! I thought I remembered something like that.
couldn't find my electrical code book anywhere...
thanks again for the quick and kind response!
Frank D.
Frank D.
You could have used a 15 amp GFI receptacle. The difference is in the slot configuration, they are rated for 20 amp feed through.
Not to get off topic...But a question for the "Pros"
The Recepts are interchangeable in the situation mentioned. Do the "T-SLOT" receptacles require a 20 amp circuit.?
