problem with just installed ceiling light
Received 0 Votes
I just installed a new lighting fixture in my living room and when I turned the electricity back on, the lighting fixture will not turn off. It is connected to a regular on-off toggle switch that worked perfectly well with the old fixture. I think I connected the wires correctly for the new fixture--white to white, and the fixture black wires I connected to the red wire and left the black bundle in the ceiling capped. Any idea why the fixture won't turn off now?
You have a constant wire where a switched wire should be.
Recheck your connections.
Using a 2 wire electric tester, find the wire that is live only with the switch turned on.......This must go to fixture "BLACK".
