Outlet vs Breaker Ratings
Old 04-15-08, 06:56 PM
I actually posted this on the tail of an older question but realized that it might not be looked at so I am reposting as a new question.
In my non-attached shop I have a subbox with a 20A breaker feeding a 20A GFCI followed by downstream 15A non-GFCI outlets. The wiring from the GFCI to the downstream outlets is 14/2 w/ground.
My question is, do the 15A outlets and/or the 14 guage wires have a potential for shorts before the 20A breaker would trip and should they be replaced with 20A outlets and 12 guage wiring? I am making an assumption that I will never have enough load at any one time to exceed 15 amps total.
Thanks for the advice.
Yoandme
P.S. - I am in Washington state
Old 04-15-08, 07:46 PM
HotxxxxxxxOKC's Avatar
That 20 amp breaker needs to go down to a 15amp or replace the 14ga wire with 12. 14ga wire cannot be on a 20amp circuit, but the 15amp receptacles are fine as-is.
Old 04-15-08, 08:09 PM
The circuit breaker is to protect the wiring, so the breaker must be sized to protect the smallest wire on the circuit.
If there was a short on the 14-2, it could heat up enough to damage the wire before the 20 amp breaker would trip.
