GFI Circuit
Old 04-19-08, 02:18 PM
Unhappy GFI Circuit
I was replacing an outdoor 15A 120v outlet. This is on a GFI protected Circuit. I installed the outlet, flipped the breaker, and heard the GFI trip. Apparently the ground wire was touching the hot wire on the outlet I replaced. The incoming 14g wire to the GFI burned at the GFI connection. So I replaced the GFI recepticle, 15A 120v.
I now have power to the GFI, but no power to the 8 some outlets beyond the GFI protection.
Ideas?
Old 04-19-08, 02:47 PM
Unclediezel's Avatar
OK....Really quick.....
Run outside.With a Table lamp.....Does The GFCI outlet work.........??????
GFCI outlets are shipped in "TRIPPED" mode and must be reset before they become functional. A solid...FIRM, PUSH.....and a noticeable "CLICK" must be heard ....
Old 04-19-08, 03:01 PM
If only it was that easy....
Thanks Unclediezel.....It worked!!!!!
Only kidding, I wish it was that easy...I have power to the bottom plug of the gfi outlet. When the gfi is "tripped" no power goes to the top plug of the outlet. When the gfi is not "tripped" I have power to the top plug of the outlet. In both cases, the power does not go beyond the gfi to the next in line of the 8 downstream outlets, however I do not know in what order those outlets are wired. Will I have to open up each outlet to see where the power, or neutral circuit is broken?
Old 04-19-08, 04:04 PM
Received 110 Votes on 100 Posts
When the GFCI is tripped there should be NO power to both outlets of the GFCI.
Old 04-20-08, 02:30 AM
i just want to remind that make sure you don't get the line and load reversed otherwise it will not function propely at all.
Merci,Marc
Old 04-20-08, 08:11 AM
Smile Thanks All
As it turns out, the next outlet in the circuit was not making contact on the hot lead, thereby not allowing the electrical feed through the whole circuit. Problem solved. Thanks.
Old 04-20-08, 09:36 AM
Glad to hear...but i'm still a bit concerned that only half of the GFCI recept worked while in "Trip" mode....
Old 04-20-08, 12:37 PM
I agree. I still can't understand how a loose connection on another receptacle could cause this. It sure sounded like a defective GFCI to me.
