electrician replaced 3/0 with 2/0
Old 04-20-08, 02:27 PM
wgc
wgc is offline
We've been having trouble with a poor connection somewhere in the service connection and just had an electrician do some work that included replacing the cable from the meter to the main panel. We have 200A service. However I noticed the existing cable was 3/0 copper while the new cable was 2/0 copper, after he left. Is that the right size? Did I lose any capacity? I saw an unrelated thread that mentioned a change in the 2008 code that might change this: would it?
Old 04-20-08, 03:04 PM
mango man's Avatar
2/0 is larger cable than 3/0 so it was a upgrade
Old 04-20-08, 05:41 PM
Mango man sorry to step on you but that is backward the 3/0 is larger than 2/0 is
however to the OP the 2/0 cu is legal size for 200 amp service entrance cable [ this is only size they will allowed in resdentail area if this is in commercal that diffrent story you need much larger than that.]
Merci,Marc
Old 04-20-08, 06:17 PM
chandler's Avatar
Received 3 Votes on 3 Posts
And making the necessary bends with 3/0 would be a bear considering the limited space available in most meter bases and panels. You're good to go.
Old 04-20-08, 06:27 PM
mango man's Avatar
well I usually work in 19 -24 ga I always thought it continued down is larger
(BTW we should all correct misposts , I'm glad you stepped in Frenchy )
Old 04-20-08, 06:41 PM
Unclediezel's Avatar
Usually...but you cant go past 0.......2/0 is actually "00", 3/0 is "000"
#3,#2,#1, #1/0, #2/0......etc.
Old 04-20-08, 06:50 PM
mango man's Avatar
makes sense
thanks unclediezel I was just going to try to Google it
Old 04-20-08, 07:30 PM
No problem we glad we can help you in the right step before it get all misundestood here
Merci,Marc
Old 04-22-08, 06:21 PM
wgc
wgc is offline
Thanks
Thank you all for confirming the smaller cable is ok. Actually, you're very right about the difficulty of bending the cable. Whoever installed it long ago took a disturbingly large notch out of the joist, that I probably need to do something about sometime. This electrician had it a bit easier with the smaller cable, but I wouldn't call it easy, not by a long shot.
I even made it tougher on him ... the electricians out there will probably hate this but I had him put a loop on both ends of the cable to allow slack for replacing the meter base and the panel, sometime in the future.
