1 ton Electric Chain Hoist
Old 04-25-08, 04:22 AM
C
Hi, I work for a newspaper. Our 1 ton electric chain hoist that we use to lift the paper rolls onto the press was noisey and now doesn't work, we're using our back up. The noise it makes is a grinding noise when it would go up or down. When theres no weight on it, it goes up and down but still grinds. When a paper roll (about 500lb) is on it, it just sits there and grinds. It's used a lot, is it worth trying to fix or just get another one?
Thanks,
Joe
Old 04-25-08, 07:21 AM
I
Received 44 Votes on 42 Posts
If the hoist makes a grinding noise, then chances are the electric motor is working okay. The problem is probably in the mechanical components such as a gearbox.
Old 04-25-08, 07:58 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Make a mistake trying to fix a hoist and someone gets killed. Definitely a job for someone certified to do that work.
Old 04-25-08, 08:02 AM
F
Sound like gearbox going bad but really i am little condersating that due you work for someone i really think it is the best you get ahold of someone who is cerified to work on the hoist due the safety reason.
Merci,Marc
ps.,, most company useally just order a new hoist on the smaller size unit for larger one they will send it to cerified repair shop
Old 04-25-08, 09:25 AM
C
Thank you all very much. I think thats what we're going to end up doing; getting a new hoist and send this one out. If the repair isn't too expensive, we'll get it done and keep it as a back up.
joe
Old 04-25-08, 09:57 AM
F
I am gald you do the right thing with the hoist and thanks for letting us know what your sisuation is.
just remember work safe.
Merci,Marc
