3 phase ac motor
Received 0 Votes
3 phase ac motor
I have a 3 phase motor on a compressor I need to know if there is anyway to connect to 2 or single phase the motor specs are as follows
us electric motor frame 182t volt 200 amp 10
design b code k rpm 1740 f9635-00-411
I have 240 available in the garage
Received 0 Votes
short answer is no you can not get 3 phase motor running in the single phase supply it will not run that way,
and majorty of the resdentail area dont have three phase supply at all.
Merci,Marc
Merci,Marc
For the longer answer see here: http://www.metalwebnews.com/howto/ph-conv/ph-conv.html but may be simpler cheaper to just change out the motor.
