Number of outlets/fixtures - Florida
Received 0 Votes
I know there's something in the Florida Bldg. Code (probably same as national electrical) about the number of outlets and lighting fixtures that can be run from one circuit. I can't remember how to figure this and am getting lost in the online code databases. Can anyone answer this question for me?
The US National Electric Code does not specify a limit on lights or receptacles on a circuit. I do not know if Florida follows unmodified NEC or if they have local amendments which may specify a limit.
You may be thinking about the commercial side of the NEC. Commercially, I think the number is 12 receptacles per circuit, but as was stated, there's no limit in residential use in terms of the NEC.
Received 0 Votes
A while back, maybe 8 -10 years ago it was a rule in the florida building code that you could'nt put more than 12 points on a circuit.
Points were as follows :
Light switch = 1 point
Receptacles = 2 points
So for example you could have 2 switches and 5 recpts. on a circuit = 12 points.
I have been out of residential electrical new construction for a while but I am pretty sure this is no longer enforced although plenty of electricans still follow it anyway. This rule always only applied to residential and not commercial
Received 0 Votes
That's it! An architect told me that. He's in his forties max and uses it.
What a silly system! What the heck does a switch have to do with the expected load on a circuit? I could have 15 fixtures all on one switch or 15 fixtures on 15 switches and have the same load. Likewise any single switch could have a 3W LED fixture or a 1500W heat lamp.
Previous Thread
Next Thread
